We have two users (One MS V8i SS10, the other PowerDraft V8i SS10). With the same support files and opening the same drawing file, each see different line type scales. The Microstation one is correct, and the PowerDraft one is wrong. Any ideas why? Thanks
Hello Matthew,
Pleas check the active linestyle scale in PowerDraft : key in: ACTIVE LINESTYLESCALE
For more info: https://communities.bentley.com/products/microstation/w/microstation__wiki/2951/setting-linestyle-scale-in-microstation
Aimable
I believe the user said that this is a single file, so the active linestylescale should not be changing simply on file open. Are you suggesting that MicroStation and Powerdraft are reinterpreting the linestyle scale differently?
MaryB
