Report Table sort by column now showing
I need to have better control over the sorting of a table that is being generated by a report. In order to do this I was thinking of making a "Sort #" column to give me control over the sorting of my rows. I would like to sort by that column but then not show that column in the report. Is this possible? I know I can always manually delete that sort row afterwards, but would rather get this working on it's own as I would have to delete it manually every time I updated the table.
  • The Groups & Aggregates Technology Preview in MicroStation CONNECT Update 16 may be what your looking for
    Carl Myhill
    Technical Support Engineer
    Bentley Systems
    Answer Verified By: Steven Tissier
  • Since this trick essentially shifts the data I had to make sure that I had my "Sort #" column at the very end of the table, but that worked. Thanks!
    OpenBridge Modeler - 10.10.00.85
    Microstation - 10.16.02.34
    Comprehensive 3 Day OpenBridge Modeler Training
