Is it possible to place a report as a table using a table seed and having that table use the table seed title & header rows (text & formatting)? I tried just turning all rows in my table seed into "body" but that did not work. It would be really nice if we could specify certain rows in the table seed to be "static" so that they carry over into reports correctly.
Hi Steven,
You can have seed with your formatting. But, the text will be overridden. Please create a sample video for what you are looking for and file an idea.
Mangesh
Basically when I place a report as a table using a table seed, I want that table to maintain/keep the text in the first 1-3 rows from the table seed, and place the report below those. In doing this I am controlling the title & header rows with the table seed as opposed to with report title and column headers of the report. This is necessary at this point due to other limitations or bugs with the table tool & table seeds.
OpenBridge Modeler - 10.10.00.85Microstation - 10.16.02.34
Comprehensive 3 Day OpenBridge Modeler Training
Steven Tissier said:This is necessary at this point due to other limitations or bugs with the table tool & table seeds
I agree that table seeds are flakey. However, Bentley Systems are not receptive to that observation.
Hi Steve,
Are you saying, you want to keep the "Title" & "Header" of the table as per seed and let the report just be the body?
Hi Jon,
The link you mentioned is clearly a Bug. Let our support file it. Do you have any other observations?
Yes, that is correct. It may not just be the first two rows of the table seed I want to keep either. That is why we need to be able to specify which rows from a table seed we want to keep when placing a report as a table.
