Since latest updates on Windows 10, the control of Display Performance goes through Windows settings and not through Nvidia Control Panel, however we got following looking:
Previosly can be improved through Nvidia Control panel but now we get the following message:
I made changes on the system but still no improvements:
My system is as it follows:
Device name ####-CAD08Full device name ####-CAD08.####.localProcessor Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz 2.90 GHzInstalled RAM 8.00 GB (7.81 GB usable)Device ID 69D03E49-5308-402D-9956-###Product ID #####-50014-69837-AAOEMSystem type 64-bit operating system, x64-based processorPen and touch No pen or touch input is available for this display
Edition Windows 10 ProVersion 21H1Installed on 15.12.2020OS build 19043.1110Experience Windows Feature Experience Pack 120.2212.3530.0
NVIDIA System Information report created on: 07/31/2021 10:58:09System name: ######-##-CAD08
[Display]Operating System: Windows 10 Pro, 64-bitDirectX version: 12.0 GPU processor: Quadro M2200Driver version: 462.30Driver Type: StandardDirect3D feature level: 12_1CUDA Cores: 1024 Core clock: 694 MHz Memory data rate: 5.51 GbpsMemory interface: 128-bit Memory bandwidth: 88.13 GB/sTotal available graphics memory: 8093 MBDedicated video memory: 4096 MB GDDR5System video memory: 0 MBShared system memory: 3997 MBVideo BIOS version: 84.06.7D.00.03IRQ: Not usedBus: PCI Express x16 Gen3Device Id: 10DE 1436 224D17AAPart Number: 2704 0000
There is something that can be done to improve the performance?
We are using on our office for Certain customer MicroStation V8i (SELECTseries 10) 08.11.09.916 and up to now we will need to be using for some time more.
Hyung Kim said:Did you get a chance to update your driver from https://www.nvidia.com/Download/driverResults.aspx/177764/en-us and try your workflow?
Good idea, but my experience is that - depending on notebook manufacturer - it can work fine, but can be risky, when anything not perfectly standard exists in notebook internal implementation...
Jan
How to check which adapter s actually used Intel or Nvidia?
Maybe it is related to this issue?communities.bentley.com/.../zig-zag-edges-in-shaded-views
It seems like it is related to that, the current design that I'm working related to the global origin, is indeed more that 22 km of distances, however with the option of "Expand the Clipping Panels Active" normally should be working properly. I also update the driver from Windows Update expecting any improvement, but no, I still have that "zigzag" looking on shaded views.
At the moment I'm just dealing with it...
