Hi, Microstation community.
I am using MicroStation V8i, version 08.11.09.919
Addition to dates and sheet numbers, we'd like to add other name, sheet title, and number fields in the border to be auto filled.
There will be more than 100 different plan sheets and the name and sheet tile will have 10 different combinations.
How can I possibly do so? I have been doing my search and I have not been able to find a clear answer.
Thank you in advance for your help!
Below is the image of the sheet border.
Yoko
you want them to autofill based on what ?
Fields have the ability to do what you want, but the information that would fill that field needs to exist somewhere.
Timothy Hickman
Main: 877 627 3772|
What kind of options do we have?
properties on an element, properties on a model, properties on a file, properties on a workset, sheet index, custom properties, etc...
That's amazing. Which one do you recommend (most efficient, less problematic)?
You might like to have a look at the following Wiki article which outlines your options when it comes to Text Fields.
Text Fields - Auto Updating Annotations
The following details in the Help Documentation may also be of assistance.
Fields - Derived Content in Text
