I mostly use Rotate by "3 points", but when I open the rotate tool it is by default "Active Angle"
Can I somehow change the default settings from Active Angle to 3 points??
I am working i OpenCities Map Advanced.
Hi Anna,
I don't know OpenCities Map Advanced, but if the option is available to you, you could do as I have done and create your own tool to always default to by points. This can be done for Rotate Copy and Rotate Original:
Johan De Cock said:By using "save settings" this is saved into the DGN file, right? Is there also a way to save it into the application preferences?
It's a design file setting, not a user preference setting.
Johan De Cock said:I use "by 3 points" 90% of the time in all of my projects
Brien Bastings's last sentence tells you what to do: change that setting in your seed file and then save settings.
If your seed files are inaccessible (i.e. set to read-only by IT policy), then use Barry Lothian's suggestion.
Thank you for all the answers!
I just worked out the keyin and put it on a Fkey so I dont use the icon or the right mouse option for rotate by 3 points just my keyin on the F key of choice... if you have fancy mouse with extra thumb button you can assign the keyin to that which is even better!
the settigns recommended wont stay if you use any other option of rotate as msnt remembers what was used last time.. so even seed wont hold if you use another option ever in your file down the line. so my F key solution or fancy mouse button it always holds.. you gotta weigh up how often you use the rotate 3 points to devote a button or a F key for a solution...
Lorys
