Microstation U16 crashed without exception and looking into Event viewer blames this DLL. Quick search shows that similar issue was fixed by Microsoft update in 2018 but seems still happens:
Bojātās lietojumprogrammas nosaukums: microstation.exe, versija: 10.16.0.80, laikspiedols: 0x60c9cf09 Bojātā moduļa nosaukums: ucrtbase.dll, versija: 10.0.19041.789, laikspiedols: 0x2bd748bf Izņēmuma kods: 0xc0000409 Bojājuma nobīde: 0x000000000007286e Bojātā procesa ID: 0x42c0 Bojātās lietojumprogrammas startēšanas laiks: 0x01d7985af763191a Bojātās lietojumprogrammas ceļš: C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\microstation.exe Bojātā moduļa ceļš: C:\WINDOWS\System32\ucrtbase.dll Atskaites ID: 31ceebba-5cdb-41b7-a695-31d59b3c6cc8 Bojātās pakotnes pilnais nosaukums: Bojātās pakotnes relatīvais lietojumprogrammas ID:
OS: Windows 10 Home (64-bit)
Locale/language pack: Latvian
build:21H1 19043.1165
Apply the following and test.
Microsoft .NET Framework Repair Tool
Visual C++ Redistributable for Visual Studio 2015-2019
IF you still have issue, generate crash logs with ADPlus
Hi Oto,
Oto said:[U16] ucrtbase.dll crash on non-English Windows
I think it's not simple relation "non-English Windows > crash", because I use Czech Windows and I have not experienced any MicroStation CE U16 crash.
Oto said:Microstation U16 crashed without exception
Windows can be configured (registry modification required) to create memory dump automatically, when specific application crashes. It can help, when ADPlus, mentioned by Leonard, does not provide enough details.
Jan
Jan Šlegr said:I think it's not simple relation "non-English Windows > crash"
Could be coincidence but maybe not related as this computer acts weird on it's own.
Oto,
I have seen a recent crash reported in Event Viewer for a user with the same dll signature (ucrtbase.dll). He was on in English Windows operating system.
What we did to remove the error was uninstall MicroStation, reinstalled Update 16 and then replace the Personal.upf in that order. I know it seems as a lot to do, but it might resolve the issue. So far your issue is only the second report that I have heard thus far regarding this issue.
This something development will need to keep an eye on.
Regie
There is another issue I encountered export to DWG doesn't work shows that Remap file is not found even that none is specified.
edit: -restoredefaults fixed issue with DWG export so seems this is indeed related to upf corruption.
Answer Verified By: Leonard Jones
