I can't get the "Move to Contact" tool to work. I click on an element, define my direction, and then nothing happens. I've got V8i select series 10 version 08.11.09.919 on windows 10.
works for me in v8i.. ss10 is your file 3d
Lorys
Currently Using V8iss10 (8.11.09.919)
and dabbling in CE update 16 (10.16.00.80)
and now
Pwise Administrator ( yeah I passed the training course!)
It doesn't work for me in SS10 08.11.09.919
2D file example:
The help file states a data point is needed to accept, yet its not asked for:
Thanks for providing the video, this is exactly what it looks like for me when I try it.
Thanks Barry, I need to copy this horizontal stirrup vertically at 6" intervals and keep them following these curved rebar. I was hoping with the "Move to Contact" tool I could just copy them all up at 6" intervals and then snap them over horizontally to follow along the curve (I figured I might have to do it to the circle at the end of the stirrup first, turn off the curved rebar, and then attach the rest of the stirrup to it that way). Is there a better way you can think of that I could quickly accomplish this? Second picture shows the finished product I was trying to achieve and ended up doing manually.
Hi Ryan,
Its unclear if its 6" intervals constantly on the Y-axis or measured along the curve. I've assumed the latter but you'll need to confirm. I've roughly mocked up your situation and would then do this:
This is the above process demonstrated.
The issue is that the copies elements retain their size but the length between curves increases. This can be overcome by doing the above process on the circles individually but you need to select the large curve which each circle is in contact with. The line I would make oversized, array as above then use the outer curve to trim. If however your members should actually retain the angle to the curve, enable 'Rotate Items' and no further work should be needed.
Does that help any?
