I can't get the "Move to Contact" tool to work. I click on an element, define my direction, and then nothing happens. I've got V8i select series 10 version 08.11.09.919 on windows 10.
Thanks Barry, I appreciate the in depth answer, however I don't think the array along path method words for me because the 6" spacing needs to be along the Y axis, not along the curve. Do you know of any way to quickly achieve that?
The lines are obviously not a problem however the arcs are potentially more challenging as the contact point between the arc varies at each location. Do you have a close-up view of the end interface?
I'm mostly concerned with just aligning it along one side, I'm not too worried about where the other end of the stirrup ends up. For background I'm just trying to lay out a series of column hoops along some curved column rebar. The hoops themselves are supposed to all be the same size in this region, so I just want them to follow the constant 6" vertical spacing and then be aligned with the column rebar as they go up. So all I really care about is keeping one side of the hoop in the same location with respect to the column rebar and the exact location of the other side doesn't matter much to me. I've just got about 30 bars to lay out in each segment so I'm just looking for anything that saves me from having to position each bar manually. Here's a closeup of one end of the stirrup if that helps, ideally along this column bar the stirrup and column bar intersection would be at the same place on the stirrup for each bar.
Ryan,
Try the method shown in this video clip.
Ron, that's awesome, thank you for that! I will definitely try that out!
