I'm running CONNECT version & when I try to change an existing dimension's properties, basically the entire drawing disappears. Please assist!
Can you provide a little more details on this issue? Is it MicroStation or Powerdraft and what CONNECT version? What properties are you changing and what exactly dissapears? A screenshot before the change would help.
It's Microstation CONNECT version 16.Trying to change entire dimension to a different type dimension I created (its an existing dimension I was trying to change to the newly created one.I also tried to input the newly created dimension from scratch, but it did the same...
This is what the drawing is supposed to look like:
Hi Karin,
if you use Select all (Ctrl + A) can you see the elements highlighted in your drawing? can you see the elements if you do a fit all
I am trying to find out if the elements are just hidden or there is no elements at all.
also what color did you apply to the dimension style? did you change the scale factor?
Maria
Maria Garcia
Yes, all is highlighted if selected.
What are the differences between the old dimension style and newly created? Can you perhaps share the file to see what is happening?
