Is there a list of recommended video cards for Microstation Connect? I've found a published list for V8i, but have not seen anything for Connect.
Thanks!
Nate
I found these recommendations to be very useful for higher end CAD (3D design and Modeling) users within our organization.
CAD Workstation Specs for 2021
Processor/Cores
RAM and SSDs
Graphics Processing Units (GPUs)
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Answer Verified By: Nate Ritchie
On the CPU note, not a lot of enterprise option provide this option, but if you can, look into an AIO liquid cooler for the CPU. As my understanding is a CPU only go into turbo speed if it's temp is under certain threshold. A standard air cpu cooler isn't effective in keeping the temperature below that threshold.
And yes, I'd follow Oto's advice and look into AMD processors. For highend workstation and server CPU, Intel seems to lag AMD in recent years in terms of processing power.
Hi Tuan Le,
Almost (or even more) important than CPU cooling is case cooling. I have seen many cases where the hot CPU and GPU air was pulled back into the CPU fan. I've even seen where the computer case was put under a desk and the hot air was being trapped by the desk & back wall. The fans would pull the hot air back into the case and then have problems keeping the CPU cool.
--Robert
