Sorry, I'm just a beginner and probably my problem is not a problem and it's something simple, what I just can't find in settings.
Please tell me why I can't draw a solid, simple line - I have it all the time half transparent & the compass looks not like in all tutorials which I've watched :/ Like compass on the hangover ;)
Many thank for help!
Unsupported graphics card. You will have to use software graphics by setting QV_DISABLE_HARDWARE = 1 or QV_D3DVERSION =0 depending on Microstation version CONNECT or V8i.Example - https://communities.bentley.com/products/microstation/m/microstation_gallery/272103
If Oto's suggestion does not work (although this is most likely the issue) it is worth looking at the User Preferences and make sure anti-aliasing is off. Also make sure there are no display styles being used for your current view. Make sure that is set to Wireframe.
Power InRoads v8i 08.11.09.615
Microstation CONNECT 10.16.02.34
Microstation v8i SS 10 08.11.09.919
ORD CONNECT 2021 R1 10.10.1.3
ProjectWise 10.0.3.453
2d or 3d file ? and how far from the center of the design plane are you ?
Timothy Hickman
Main: 877 627 3772|
Dear Oto. Thank you a lot!!!
Your suggestion let me think about the problem in other way. I spent 3 days on checking the app settings but the problem was somewhere else.
I found the solution:
I had to open MS properties and select 2 options:
1. Run this program in compliance with Windows XP (in my case)
2. Run this program as Admin
(Sorry it's in Polish)
Anyway thank you a lot!
That is expected when running unsupported version SS3 on Windows 10.
