Sorry, I'm just a beginner and probably my problem is not a problem and it's something simple, what I just can't find in settings.
Please tell me why I can't draw a solid, simple line - I have it all the time half transparent & the compass looks not like in all tutorials which I've watched :/ Like compass on the hangover ;)
Many thank for help!
Hi I am also facing the exact same problem. Can anybody please elaborate the method to make it normal? I am using v8i SELECT series 10
Sadip Baral said:acing the exact same problem
can you send/ post a small copy of your DGN file here so we can see some settings then we may be able to diagnose whats wrong....
Lorys
Currently Using V8iss10 (8.11.09.919)
and dabbling in CE update 16 (10.16.00.80)
and now
Pwise Administrator ( yeah I passed the training course!)
It is not file dependent but it is graphics glitch with know bad graphics drivers. Set QV_D3DVERSION = 9 and it will go away but it is not recommended for intensive 3D use.
Hi Anna and Sadip,
Anna Zawada said:I have it all the time half transparent & the compass looks not like in all tutorials which I've watched :/ Like compass on the hangover ;)
Sadip Baral said:Hi I am also facing the exact same problem. Can anybody please elaborate the method to make it normal? I am using v8i SELECT series 10
Oto is right, the problem is likely related to DirectX and graphic driver compatibility. You can search e.g. for "ghost lines" phrase (and similar ones ;-) to find more discussions about the same topic. In this context, the request to share file example makes no sense.
It's recommended to follow the best practices and to share as much information as possible: In the discussed case it's not only product and its (exact) version, but also Windows version, used graphics card and graphics driver version.
Typical source of the problem is not whether MicroStation is or is not supported on Windows 10 (even when it's important fact), but quality of DirectX support ... which for some cards and older drivers is not very good, even when used with Windows 10.
MicroStation V8i SS3 and SS10 prefer to use DirectX11, and when it is not supported, DirectX 9 is used (and when even DirectX 9 is not available, software acceleration is used, but such configuration cannot be used for MicroStation). I remember, that quite often - especially older graphics cards - "announces" to Windows that they support DirectX 11 (so MicroStation used it), but the quality was horrible (because of wrongly implemented drivers).
The solution I used with my customer was:
When it does not help, the solution mentioned by Oto to set (create when does not exist) QV_D3DVERSION = 9 is the best solution (there is also file that sets this variable on global level in Windows).
With regards,
Jan
Hi Oto, where to set this code, please let me know in detail. I am a novice microstattion user. Thank you.
