Hi
I have a filled shape in a nested reference (ref. 1.1) that hide linework in another nested reference (ref 1.2) (1 level of nesting).
I have tried changing element and level priority but still the fill shows above the lines. The reference priority cannot be changed because of nesting.
I have also tried changing the update sequence in the file attaching directly the references (ref 1) and it does not seem to have changed a thing.
Has anyone else had this issue? What should I try next?
Thanks.
MicroStation CE Update 14 10.14.02.01 in a 2D design model
Hi Alexandre,
to better understand your situation, can you check how display styles are set?
Jan
Jan Ĺ legr said:Without further details, the discussion is quite hypothetical and no clear advice can be provided
Lorys said:The quickest solution ... still may not work in all situations...
I agree with Jan and Andrew Bell: the OP must supply vital information so that we can provide meaningful answers...
I agree - a few more details would be helpful.
If you open the directly attached reference (the one containing the nested references) does the shape still appear on top of the linework ?
Timothy Hickman
Main: 877 627 3772|
I am using MicroStation CE Update 14 10.14.02.01 in a 2D design model. I usually mention it at the end of my posts, just slipped my mind this time around.
Thanks that quick work around is helpful for now.I would like to find something more permanent though as it is for linear infrastructures and many sheet files use the same reference, and the workaround needs to be implemented in a large number of files.
