Just come across a new bug (for me) in CE today.
When GO= is set too far away from design cube origin, "center of mass" will be display in wrong location when using "measure volume" tool (similarly, wrong "centroid" location for "measure area" tool). I haven't got time to pin point the threshold of how far is "too far".
What I see and expect in V8i SS10 - 08.11.09.931:
What I see in CE 10.16.00.080:
If it's a known (not yet known) defect, would be great if I can get the defect number. If it's not a defect, an advice to get the correct centre of mass in CE for the attached file would be much appreciated.
Best regards,
Tuan Le
7217.TEST.dgn
As I notified you, this issue is linked with the BUG 659406: Solid's Center is not measured correctly in CE. I will keep you updated on the ticket that you raised.
Thank you very much for reporting this issue.
Benedetta
Answer Verified By: Tuan Le
