language setting - popup missing[CE16]
I am using microStation in a localized version.
If I want to do screenshots to post in the English forum or for a service request I switch the language to English.
But then the popup [spacebar] does not work any more... (when switching back the language its ok again)
Probably this is due to the fact that the path is translated !?
