Hi.
Why if I select a Dimension style (blue triangle icon) and then right-click to select "Update From Library", that Dimension style does not update? Icon does not change to green stick?
If I do this in a "Text Style" dialog with an style (bule triangle icon) and then "Update from Library", it works...
Hi Barry, apologies but this is exactly why we need separate threads for separate issues. I was responding to the previous comment regarding Dimension Style comparisons...
Hi Robert,
Understood, fully agree regarding separate posts for different issues.
I think the bug still exists.
I am trying it with OpenRoads Designer CE - 2021 Release 1 - Version 10.16.00.80 Windows x64 , Using RealDWG 2021
And it uploads all properly but it ALWAYS changes the FONT to "0060_Engr Vert Bold_Ctr Ctr" when I didn´t change the Font in the Dimension Sytle (just another properties).
Obviously, it is not the original Font of the Dimension Library (you can see the difference in the attached image). For this reason, that style still has the blue Delta icon..
That Font is not the active Font, so I don´t know why MS puts that type of Font...
Yes, there are issues with the Update from Library. I just saw this again today where I changed the Text Style being used in a Dimension Style. After I test the function I was experimenting with I used the Update from Library option. The Text Style did not revert to the Library style. I had to manually switch the text style then click Save. Only then did the blue triangle switch to the green check icon indicating the library matched.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Sorry, I wanted to say the "Text Style", not the "Font" property. Same issue as you.
