MicroStation CE 14
Hi.
in the "Text Style" dialog if I edit my active text style and then I close the dialog then I don´t get any message regarding if I want to Save the unsaved style.
Even if I close the dgn file and I open it again the text style reamins unsaved.
I have tested this in "Dimension Style" dialog and works I hope. (an unsaved Dimension style which is also the active style)
If my unsaved style is not the active style then I get that message: Do you want to save the changes made? Y/N
Thanks.
Thanks for highlighting this issue. I was able to reproduce what you have described. I have raised BUG 712407 to the development team to investigate and fix this issue for a future release. You might like to raise a new Service Request that can be linked to this.
Answer Verified By: Joan Martínez Serra
Hi Andrew Bell
Look also this:
communities.bentley.com/.../question-about-dimension-styles-in-the-dimension-styles-dialog
