Why don´t update Text elements when I save the Text Style?
MicroStation CE 14.
Hi.
I have read that if I insert Text with a particular Text Style (in this example: "amarillo" style) and I edit that style (without saving it) and I insert other texts but I finally save the style then texts with that text style would update according to the saved text style.
I have done this (changing the height every time) but when I save the text style, just the first text uppdates.
I don´t understand why the second and third text don´t uppdate. (If I replace the text style in the properties pallete and then I select the same text style), the Height remains the same.
