Hello all,
I'm dimensions some pipe runs and I can't figure out how to get from decimal to stacked fractions. I've turned ON stacked fractions in the dimensions style, but that didn't help.
Running CONNECT btw.
Any thoughts?
Under the Units tab of the Dimension Styles dialog check the accuracy setting and make sure it is set to a fraction rather than a decimal value. If you want the working units for the file to be stacked fraction by default go to the backstage Settings File Design File and set the accuracy to a fractional value
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
