When switching active levels using the attributes tool bar is it possible to have the associated attributes change with selected level? They are already set in the Level manager. I used to be able to do this in the past. Example. My active level is "Trees" and is the color "green". I need to change the active level to "sidewalk" which uses the color "yellow". In the past when I would switch between levels the associated attributes would change at the same time. Now I have to change the level and the attributes separately. using v8i 10
There is an MDL program delivered with V8i SS10 that does what you need - synchbylevel.ma
Just load that MDL and it will automatically set your color, weight, and line style attributes to bylevel every time you change levels.
Note: In the CONNECT Edition this it has been added as a User Preference under the Operations category.
Rod WingSenior Systems Analyst
Answer Verified By: Sarah Gentner
Thank you! Is there a list that explains the various MDLs?
Nothing that I've seen. Some of these are loaded automatically by various tools.
