Hi.
MicroStation CE 14.
If I press the button "Toogle AccuDraw" to turn of AccuDraw and then I do "Save Settings" if I try to open the same drawing again, AccuDraw is ON again when I draw a line.
Is this behaviour correct? or it is a bug?
Thanks.
OK, solved.
In the AccuDraw Settings I have to disable "Auto-Load".
This way If I open the drawing and try to draw a line, then the AccuDraw is not operative.
Answer Verified By: Joan Martínez Serra
Good to hear that you've been able to apply a resolution to your issue. You might like to look at whether your User Preference File (UPF) is operating as it should as when you perform a Save Settings this should have stopped AccuDraw from remaining turned on. It may be an issue with the permissions to save this setting into the UPF so it might be worth looking at the permissions of this file / folder. Another suggestion could be to reset your UPF and clean out any temp files.
How To Reset User Preferences and Delete MicroStation's Temporary Files
why wouldn't you always use accudraw to draw lines...? I won't work without accudraw and accusnap... so much more efficient, I never have to do a construction line or offset..
Lorys
Lorys said:why wouldn't you always use accudraw to draw lines...?
Freehand sketching lines and especially curves. I turn it off only occasionally, but not a big deal, on or off, right there on the ribbon.
For me, it is annoying to add text or to add points typing coordinates
