Hi all
I was wondering how can I attach Item Fields (metadata) at the cell level and not to an element in the cell.
So when the cells are placed these Item Type Properties already exist or preset
MicroStation CE Update14
OpenBuildings Update 8
Hi Ian,
Ian Mackinnon said:I was wondering how can I attach Item Fields (metadata)
I guess you mean Item Type, not Item Fields (because such thing does not exist in MicroStation).
Ian Mackinnon said:at the cell level and not to an element in the cell.
Open the cell library and in Explorer, use Attach Item option to attach Item Type to model (cell).
As described in documentation, when Item Type is attached to a model, that is used as a cell, it's copied and attached automatically, when the cell is placed.
With regards,
Jan
Answer Verified By: Ian Mackinnon
Thanks Jan - exactly what I was after
Hi Jan. Thanks for this post. It helped me with attaching Item Type to one of my element in Cell Library and make this Item Type editable when element from Cell Library is placed into DGN model.
