Does anyone know the significance of the green filename in Raster Manager? I haven't found any reference to it in the help or here.
I think I've seen this occur occasionally after fixing a broken filename (red), but I'm not positive. It's not a new phenomenon.
Ustn CONNECT 16, Descartes, OpenRoads/OpenBuildings, ProjectWise CONNECT 3.2
I've never seen this being green personally. It's either clear or shows red if MicroStation cannot find the path. Possibly could be your theme being used? I notice your background is black whereas mine looks like the image attached.
yes I agree but if your going to use Dark theme aka ".. make it look like Autocad please? "
Then all bets are off as to what colours mean, when you've gone over to dark side ( no wonder it is called dark theme)....haha
Lorys
There are things in the Dark Theme that need refined for sure, but this is not related to theme. I've seen it previously in CONNECT and V8i as well. Everything works fine, but the green is curious so I'm finally asking.
I use the Dark Theme as well. I tested by attaching a raster image. I closed the file, move the raster file to a new folder in Windows Explorer. I reopened the file to see the raster was not found and was red. I redirected the path to the raster file and I did not see the raster file show green in the dialog.
I have not been using dark theme very long and I have not been using CONNECT or ORD in production yet so maybe you stumbled across something. It could just be a video driver anomaly
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
yep sounds like a video card thingy
