Does anyone know the significance of the green filename in Raster Manager? I haven't found any reference to it in the help or here.
I think I've seen this occur occasionally after fixing a broken filename (red), but I'm not positive. It's not a new phenomenon.
Ustn CONNECT 16, Descartes, OpenRoads/OpenBuildings, ProjectWise CONNECT 3.2
Nay nay. I vote no on video card thingy. Other users have noticed it on other PC's as well. It's not a brand new phenomenon. I've observed it on Windows 7 and Windows 10, in Ustn CONNECT and V8i, on PC's and more than one laptop. It hasn't caused any issues, so I never did any real investigation. Maybe it's time.
I will do some experimenting and report back.
Yeah I've been trying to replicate this myself as I've never seen it happen in all the years I've used MicroStation. I've had no luck as of yet in replicating but it is a very intriguing phenomena.
Do you change your Windows themes so the windows headers & background colors are different from the defaults? That's the only thing I can think of that would cause the issue you report.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
It's not a colour scheme issue. I'm confident of that. This is the same file open in Ustn V8i SS10:
OBD CONNECT Update 8, Dark Theme:
Same OBD, regular theme:
We haven't seen it in the References dialog, only in Raster Manager. The green persists between sessions of course and a second copy of the same TIF displays normally:
Curiouser and curiouser...
0673-64220-9003-001-MED001-D.dgn
0673-64220-9003-001-MED001-D.tif
Sample files attached if anyone can confirm the green.
