I try to draw a sloped line with AccuDraw. I tried this tutorial but it didn't work as expected: https://envisioncad.com/accudraw-with-popup-calculator
For example I input 1000, 1000, 1300 coordinates for the first point, second point will be 40 meters away with %5 slope. In distance, direction mode, I input dist: 40 m, direction: 40 degree, Z: pressed * and input 0.5. Elevation didn't change. I expect that it calculates 40- (40*0.5) How can it be calculated from the first elevation?
Edit: corrected (Z * slope) to (distance * slope)
mwlong said:Once placed check the elevation which should be either 1341.99 or 1262.01.
1300+(40*0.05) = 1302m
1300-(40*0.05) = 1298m
Thanks for checking the math. I did not double check it. I was also converting to imperial units.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Thank you, When I try, it works for positive direction like 40(hit)*(type) 0.05. When I do 40(hit)*(type)-0.05 it doesn't. When I type -0.05, multiplication symbol is subtraction symbol so it subtracts the distance from 0.05. It may be about AccuDraw settings, I will check it and I will try again.
Positive slope is ok:
Negative slope changes multiplication to subtraction:
Hahaha I did a big mistake about Z x Slope. I calculated it manually with distance x slope but typed wrong in my question. Sorry :)
Thanks Lorys, it is just simple math like distance * slope. Now I learnt it with AccuDraw. I don't know about Dots standards, I downloaded some. I will take a look if there are useful scripts.
