[CE U13] Select elements by Item Type property(New)
This has been asked before but my approach is slightly differernt.
I have Item Types attached to shapes.
I want to be able to edit the properties of all shapes with some Item Type value.
If I use Explorer I can easily select all element that match the search. The problem is that it's the Item Type that is selected, not the shape so I cannot use properties to change eq fill color of all matching shapes.
Some easy way out?
/Krister
