Microstation SS10/CONNECT, key in "Change dimension view 1" does not work anymore.
Hello.
The following key in that would rotate dimensions to the correct view doesn't work anymore for Microstation SS10 or Microstation CONNECT edition.
If I rotate a sheet I used to be able to key in "change dimension view 1" and all the dimensions would update to the current view.  This was very useful but now it's not working.
Please fix.  Or is there another way to accomplish updating the dimensions / text to the current view??
