I am trying to upload some custom made icons into my Microstation Powerdraft, however they are not displaying in my ribbon.
Lets say I'm trying to add this Panda as an icon.
I have imported the Panda icon into my current project.
However when I select the Panda and hit the 'OK' button...
The Panda icon does not appear, and of course when I hit 'Apply', the button is there but the Panda icon is not.
The Happy and Sad face icons are inbuilt icons and not custom made.
Could I please have some help with this issue? Or be redirected to a thread that has solved this issue previously?
Thanks!
your icon name has a space in front of it, however now that i look at it i'm guessing the issue is that is where your icon is supposed to be looking at my own.
Any chance you could post your .ico file and the original bmp? That might help sort out the issue.
Sorry, I'm not quite sure how to upload files effectively on these forums.
Below should be the Panda icon.
Panda.ico
And this link should take you to an image search where I got the original .bmp from.
https://www.google.com/search?q=.bmp+pictures&safe=active&rlz=1C1GCEA_enAU966AU966&sxsrf=AOaemvIMbZjv7jsouiH3bV3uj-6vrxkEHw:1633913981949&tbm=isch&source=iu&ictx=1&fir=52nI8lC4R345XM%252CQzoMQ06tucC5FM%252C_%253BM-MMTcWy5kIdXM%252CSpKdfYOupcTwhM%252C_%253BZ7ACBnoFGxcFpM%252CJSiaoA6b1JdkhM%252C_%253By8UVS6CPh074TM%252C-ZaoqqrRRnq8lM%252C_%253Bx0xwwHQhlcBXbM%252C-2lB99bABYJo3M%252C_%253BVh5Di11cHQNUyM%252CT_nsIgtjVdz8ZM%252C_%253BS6BYuHDBBCpm8M%252Czz8rrh5oapaRbM%252C_%253BS4nR5QnI8TdjkM%252CTFtN_GuzuATTEM%252C_%253Bv71WzY8q1LGz6M%252CnQ8OIW6jnNFgXM%252C_%253BBgUKPW_mby0N8M%252CwRfVrIaVmwwIIM%252C_%253BOIq7xpilQzdZ3M%252CVZor7Hh3xgrBCM%252C_%253BCEfWjGTtQ0j4bM%252CJSiaoA6b1JdkhM%252C_%253BufhQqCiOlghW1M%252CTFtN_GuzuATTEM%252C_%253BmaChMcblsXlODM%252C5LF1OZ3ezADBVM%252C_&vet=1&usg=AI4_-kQa71IO2q_lMHf2boYFxwa0Kzl_iQ&sa=X&ved=2ahUKEwjO9vLzk8HzAhUKzjgGHaJODuEQ9QF6BAgPEAE#imgrc=M-MMTcWy5kIdXM
Thanks for your help!
Darrian Low said:Below should be the Panda icon
That file contains a single 32-bit 48x48 image...
That's strange,
I'm sure I clicked on all the sizes when converting to an .ico file.
But it seems to only give me one size instead.
How would I know if I've converted it correctly?
Darrian Low said: It seems to only give me one size. How would I know if I've converted it correctly?
You get four icons...
panda_N0J_icon.ico
