I am trying to upload some custom made icons into my Microstation Powerdraft, however they are not displaying in my ribbon.
Lets say I'm trying to add this Panda as an icon.
I have imported the Panda icon into my current project.
However when I select the Panda and hit the 'OK' button...
The Panda icon does not appear, and of course when I hit 'Apply', the button is there but the Panda icon is not.
The Happy and Sad face icons are inbuilt icons and not custom made.
Could I please have some help with this issue? Or be redirected to a thread that has solved this issue previously?
Thanks!
Darrian Low said:Unfortunately, it's still blank, any idea why?
Could be a problem with icon size. Did you create an .ico file with multiple image sizes as Grant Wood suggested?
.ico
This would be my guess, I nearly always start with a 48x48 .png and I create them in batches in a range of sizes.
It also appears you might have a tab or space in front of the icon name where you typed it into the ribbon? If so that will mess things up for sure. You might just need to fix that.
-Grant
Yea, I'm using the site Grant has kindly shared.
I select all the sizes possible for one icon and select 'Convert ICO'. By any chance would you know if that's correct?
That should be right did you double check you didn't have a tab or a space in the name when you typed it?
I'm very sure there are no spaces in the name.
Just to be sure, could you please clarify which one I'm supposed to be checking? Am I meant to be checking the 'Label' or the 'Icon Name'? Or maybe perhaps there's something else that I'm missing altogether.
Thanks for your support.
EDIT: I simplified the icon name to 'Panda', hence why it's different to my previous images.
