When I click Reference Tool Bar it just shows small box only, could not expand the box and could not see the reference files as shown below. How do I expand this box.
Suresh
Don't click the down arrow, Click the button itself. That should open the full dialog, and you should be able to manipulate the size back to something correct.
If that doesn't help, let us know.
MaryB
As MaryB suggested it may be easier for you just to click on the main icon to open the full dialog and manipulate the dialog. This issue may also be related to either a graphics display issue or an operational issue with your MicroStation installation. First try the following Wiki options to ensure you have the latest graphics card drivers and to check for other settings that may affect your system.
Troubleshooting Graphics Display issues
You might also like to perform a repair of your MicroStation V8i SS10 installation if these don't help.
Repair apps and programs in Windows 10
You might also like to reset your User Preference File and clean out any temp files that might be affecting your system.
How To Reset User Preferences and Delete MicroStation's Temporary Files
Thanks Mary B and Andrew,
this operations did worked and now can see the reference box.
Suresh Pradhan
Answer Verified By: Suresh Pradhan
I'm glad Andrew was able to get you to the right solution.
Would you be able "Verify Answer" on his post? That way, anyone who might have the same problem in the future will see that you found an answer that works. Thank you.
