Label Line ( Oct 2021 )
It seems to me that the <Label Line> tool no longer exists/works.  I found <Label Element> and <Dimension Element> but cannot get either one to label a line with it's info. ( Line length and angle in dd.dddd or dd mm ss.
Both my settings in Design File Settings and the angle format in the Dimension Styles tool box are set to DD^MM'SS"
I'm using MicroStation v10.14.2.1 ( I hope...that's what shows when I view the file properties )
This:  https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v17/en/GUID-92EBADAF-1A75-B755-3F30-B0ACD6C4DD61.html  Is just not doing what it says it should.
