What´s the difference between Text and "Place Note-- Callout" ?
What exactly does "Callout" mean?
What is the difference between Text element and "Note" (created from "Place Note"--Callout")  ?
If it is a Callout, can I add later a leader to that element?  Convert Note to "Note with Leader".
  • Years ago, there was a version of Fence Stretch that also allowed for a "Scale Stretch" and a "Rotate Stretch". That was fantastic for exactly that sort of thing. Unfortunately, it disappeared, never to be seen again. A lot of people don't even remember it. I didn't use it often, but it was the perfect tool for rotating the text of a note while leaving the terminator end alone.
    *sigh*
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • You know, there is an oddity with the note. You cannot rotate the text and in-line leader independent of the leader. However, if you use the Delete Element tool and select the text, the text & in-line leader are deleted, but the leader remains. You need to delete that separately (unless you use graphic group lock). One would expect all the elements of the note would delete by selecting any part of it. So while they are associated in one manner, they are not in another. That makes it a very odd element.
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
