MS CE 16
Hi.
I have some patterns in my drawing and when I do Zoom IN and OUT it seems that there is some delay or a portion of the pattern (case of the triangle) is showed later.
Is this normal?
I think that the spacing in the pattern is not enough small to do this. Moreover my graphic card is a Nvidia Quadro RTX4000
Also, when I do a lot of zoom, the pattern is showed in gray instead of its color.
Ok, solved.
The active Line Style was very complex: "3D cable barrier" so it was drawing cells in that line style.
Answer Verified By: Joan Martínez Serra
Good to hear that you've been able to resolve your own issue. It would be even better if you could provide an outline for how this was resolved. Just for anyone in future that may come across your post with the same query.
Well, I drawn a Shape but it was a huge area so if I create a "Hatch Area" with small Spacing it is obvious than software collapse.
In my case, the active line style was a complex line style (which included cells) so when you create a hatch it takes that active line style.. software has to draw a lot of complex lines...
Joan Martínez Serra said:o if I create a "Hatch Area" with small Spacing it is obvious than software collapse.
Yes, there is probably no technologically possible to draw millions (or I guess more) elements in dynamics.
But, may I ask, why you need to create a hatch or pattern, that is so small, that is not visible? I think it is a purpose of hatch / crosshatch / pattern "to be visible".
With regards,
Jan
