MS CE U16.
Hi.
When I do "Hatch Area" to a shape with "Flood" and "Associative Boundary" is enabled and "Snappable" is also enabled then I get the "Associative Region" element.
If I open the property palette to "Associative Region" element then in the "Extended" category there is the property Snappable= Not Snappable but If I try to draw a Line String (AccuDraw is enabled) and move the cursor on the hatch I can snap.
If I change the property Snappable to "Not Snappable" then I can still getting snaps on the hatch..
So it seems that this property does not respond well.
Solved.
"Snappable" is a pattern parameter. It does not appear in the Properties palette.
We have to edit it from "Change Pattern" or directly from Tool Settings Window. Here I have an example:
communities.bentley.com/.../is-there-any-way-to-put-a-pattern-with-snappable-enabled-or-not-once-we-have-created-the-pattern
Answer Verified By: Joan Martínez Serra
Good to see you've been able resolve your issue.
