Hello! I have a map that is divided in to many different size areas. Majority of these areas contain a smaller area inside them. The areas are divided to their own layers according to their type. I would like to calculate the area of all certain layer elements but I don't want to count in those smaller elements inside.
I know that it is possible to calculate the area of an element using flood and the locate interior shapes. But is there a way to do this for multiple elements at once? Without having to click every element separately?
Thanks in advance.
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
RoosaK said: I would like to calculate the area of all certain layer elements
My answer depends on the version of MicroStation that you are using.
Write a Report that harvests data from shapes. Here's an example of an area report.
Try this...
RoosaK said:I don't want to count in those smaller elements inside
Are those on the same level or a different level?
it would depend if the areas were or are created with holes ie look like a donut or toroids if they are not do nuts then you could do as Jon suggested select all the areas by the level record the answer then measure the inner by level and sub track the two answers .. if they were all donut type shapes and an all on one layer then measure the selected areas by the level would give the total area of all the shapes elected ... personally I would do a data clean up first to make sure there are no duplicates...
some people make one shape for the fill and another shape for the out line .. silly really as a shape just has the outline fill turned on or off no need for two shapes... could you please post a typical sample in dgn covering both some inner and outer shapes so we can determine best method for you also can you export a list of the level names to see if levels can accommodate filtering for measure area by level names...
Lorys
Intro: I write here as a total newcomer (sole developer, semi-retired, U.K.) trying to understand the MicroStation and general CAD world just by browsing around. I do not even have a MicroStation licence so my ideas at this point are theoretical. And I have dual boot Windows + Ubuntu.My interest is in UI automation across multiple tools (Windows and Ubuntu, including open source tools interworking with tools such as MicroStation).Your post: Now I understand that MicroStation has a feature to export .SVG instead of the usual other file formats such as .DGN.https://communities.bentley.com/products/microstation/w/microstation__wiki/33631/import-export-third-party-file-formats---connect-editionBut exported .SVG can be parsed and saved from Inkscape as .DXF to be imported.Perhaps an alternative to exporting .DGN which can only be opened by other MicroStation users (in Windows). Here I am in Ubuntu.If that is the case with your map, I theorise that a python script can be written to calculate aggregate area of identified SVG outer elements in your exported map.svg and then calculate aggregate area of identified SVG inner elements (the "inner islands") and deduct. areas. Without touching the MicroStation UI.SVG allows scripting and batch processing of elements; an alternative to the manual workflow through the UI (e.g. the measure area tool).The SVG path element can be used.https://www.w3.org/TR/SVG/paths.html#PathElementOther contributors more experienced than I have suggested posting a sample .DGN file. Likewise, to test this idea, can you post a sample exported .SVG file?Again, these are ideas coming from this outside observer. I hope it answers your question below:
RoosaK said:But is there a way to do this for multiple elements at once? Without having to click every element separately?
David Law said:Your post
Whose post? Are you replying to this thread? Several others have responded, but we don't know who you are citing.
David Law said:I understand that MicroStation has a feature to export .SVG
What has SVG to do with this post's question about measuring area?
It seems that you want to introduce complexity to solve a question about MicroStation. MicroStation is able to make many kinds of measurement: linear, area and volumetric. The OP wants to measure the area of several elements, which is well within MicroStation's capability.
David Law said:Exported .SVG can be parsed and saved from Inkscape as .DXF to be imported
Another unnecessary tour of other technologies. MicroStation can read and write DWG and DXF files without conversion.
David Law said:My interest is in UI automation
Not sure what you mean by 'UI automation'. You can automate MicroStation, but I'm not sure why you would want to automate its UI.
MicroStation has several APIs for automation: VBA, C++ and .NET.
Oh dear, grasshopper here has touched a raw nerve.The post I am referring to is that of OP, of course, not the subsequent contributors."What has SVG to do with this post's question about measuring area?"It is directly relevant to the question. Please read my last paragraph referring to OP's closing question. i.e. batch processing not UI clicking."Not sure what you mean by 'UI automation'. You can automate MicroStation, but I'm not sure why you would want to automate its UI".For a number of reasons (perceived by me, admittedly). I am not referring to VBA etc. (internal macros in which clearly you excel).to allow a remote coach "drive" the user's session, from if need be a Ubuntu platform.to offer an alternative to YouTube tutorials where the learner has to squint at screenshots and listen to narrativesto interoperate (ODA style) with open source tools such as Blender, SVG, Wolfram, Inkscape, BRL-CAD, and other like ideas.to add text translation features.to link to the vast corpus of manuals as the session proceeds.Think in terms of connecting multiple "microservices" where Microstation is just one microservice."The OP wants to measure the area of several elements, which is well within MicroStation's capability".No doubt, if user is patient enough to click on all the required elements."Another unnecessary tour of other technologies. MicroStation can read and write DWG and DXF files without conversion".I do understand, but muggins here has no Windows, nor MicroStation currently in use. I challenge you to answer the question without MicroStation at hand.You do have Python3 in Windows. That is all that is required, I submit.Yours respectfully, acknowledging your considerable experience. But you are buried in MicroStation thinking.
0
