I have the Microstation Connect Edition. I tried to download GDOT's workspace, however it will not open and says the file cannot be read in that format. How do I download a workspace and have it be functional? Thanks.
Hi Brendan,
are you using MicroStation Connect or OpenRoads Designer Connect edition? From where did you download this workspaces?
If you are working with ORD I suggest you to post your questions in the proper forum https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum#pifragment-25841=1
Review
http://www.dot.ga.gov/PS/DesignSoftware/OpenRoads
if working in MicroStation review http://www.dot.ga.gov/PS/DesignSoftware/Microstation
you can read in the note below the following:All files designated as ".exec" files will need to be renamed after download to have an extension of "exe
Maria
Maria Garcia
I am currently using Microstation Powerdraft SELECT.
