MS CE U16.
I have read some topics about Origin coordenates of a text sometimes crash but toppic was since 8 months.
In my case if I try to edit the Z Origin of the text (in a 3D model) from the properties palette, it does not get the new value.
I have to change the Z origin of the text if I was to Move the Text using relative coordinates.
That looks like a bug, from what I can tell, as V8i doesn't behave like that and its not WAD. You seem to be finding more bugs in CONNECT than Bear Grylls in a Jungle
As an aside Joan, it might be worth you looking into setting up your own custom Tasks Dialog as you don't have much screen real-estate with all those random toolbars scattered everywhere. The ribbon appears to not be to your liking, so with a custom Tasks Dialog, you would be able to hide the Ribbon and have a lot more space for your view window(S). Also, I highly recommend keeping the AccuDraw active at all times, unless you encounter the rare occasions when disabling it is necessary e.g. drawing stream lines (I keep a button on my Main tasks for toggling it on/off).
Hello Joan,
Greetings...!!!
I tried to reproduce the issue but it is not reproducing at my side. Please help us with the following information to investigate the issue.
If possible, please provide us with the dataset (*.dgn) so we can check/test the issue.
Thanks and Regards,
Dhiraj Badgujar
Also mentioned previously here and already has a defect #:
https://communities.bentley.com/products/microstation/f/microstation-forum/213095/z-origin-of-text-in-properties-stopped-working-connect
Defect 1128448: Cannot Change Geometry Z Value Of Text In DGN Files
Thank you for making that walk-through example.
This has been broken for the past two releases. Last version where this worked is U14.
