Hi all,
On my 'Element Selection' the column to short level by 'USED' is not there.
how can I bring this back?
Marina
Hi Marina,
Do you have any elements selected when the dialog was displayed?
No element was selected at the time. But I remember having this right column with 'used' and be able to sort the element (when they were not selected) from used (with the dot) and not used (blank).
Am I imagining things hahaha?
You might be confusing the display of the level manager which also has a used column and displays the 'dots' regardless of any element selection, or just remembering how the element selection dialog looked when you had some elements selected.
