Batch Convert: On / Off Levels
I am in the process of Converting all of our V7 files to V8 (over 10,000 files). I am using Batch Convert with the csv option for Level Mapping.
The Issue:  The New Converted V8 files have all the levels turned on. So they don't match the Existing V7 file.
What has to be done so that the New V8 files has the same levels (on / off) as the V7 file?
FYI: I need all the levels converted but I need them to be off if they were off in the V7 and I need them on if they were on in the V7 file.
Thank you,
Gilbert
