I am trying to connect to Oracle database ( Drawing > Attach > Database > Connect to Database ) via ODBC. ODBC connection is setup already and I get message on Message center ' Database server is not active'
Any idea what is missing ?
Hi Rakhi,
Rakhi Bhargava said:and I get message on Message center ' Database server is not active'
In what step of the workflow do you receive this message? After you select ODBC data source in dialog? Or before?
Jan
It is after we select 3 dots .... under ODBC tab.
We are in process of upgrading to Connect series and today, I have noticed 'database server is not active' message appears on our current environment which is V8i Microstation but its open the Select datasource window shown below but Connect series does not open this window.
