I am trying to connect to Oracle database ( Drawing > Attach > Database > Connect to Database ) via ODBC. ODBC connection is setup already and I get message on Message center ' Database server is not active'
Any idea what is missing ?
If the "19C" data base is not supported, then it is not supported. Your client machines run a version of Microstation that does not support "19C", and so probably do not function with that database. There is nothing you can do to make 10.15.0.74 support a file that version doesn't support. I do not think there is any way to "trick" the software.
You could change those computers to whatever version DOES recognize your file, or you could change your database file to a supported version.
MaryB
Hi Rakhi,
Rakhi Bhargava said:and I get message on Message center ' Database server is not active'
In what step of the workflow do you receive this message? After you select ODBC data source in dialog? Or before?
Jan
It is after we select 3 dots .... under ODBC tab.
We are in process of upgrading to Connect series and today, I have noticed 'database server is not active' message appears on our current environment which is V8i Microstation but its open the Select datasource window shown below but Connect series does not open this window.
Thanks Mary, I will try to find solution for this issue as it is not possible to change to another Microstation version due to compatibility issues with other Bentley products we are using
