I've noticed that you lose the ability to access the right click group settings when the ribbon is minimised. Is this WAD or BUG?
Hi Bear,
We normally do right click on top of the Ribbon tools grouping when we need to add\remove additional tools in that specific Group in the Ribbon. Like for example if you want to remove from Placement group the Place Smartline tool.
BUT, Is there any reason why you would like to change the tools being displayed on the ribbon when the ribbon is minimized?
Maria
Maria Garcia
Thanks for the reply Maria. I've had a number of users, including myself, who want to change things around while the ribbon is out when in used in the 'minimize mode'.
I believe Enhancement (Product Backlog Item) # 662610 that had previously been raised is a request for this type of operation. If you wanted to be included for updates on this request if you could raise a new Service Request and we can link this to you request.
Right-menu-button inside minimize Ribbon
User I want to be able to access right-menu when the ribbon has been minimized. Currently if you have the ribbon minimized you have to maximize the ribbon and then go to right menu.
Will do, thanks Andrew.
SR number 7001320909 logged.
