Need to change a text style to have it be pushed down slightly while staying left top justified. A negative number for the "Line Offset Y" would do it.
Running 08.11.09.919
Using an offset value just moves the text away from the placement node. If a negative value is not accepted you can just use a carriage return prior to adding your text so you have blank line of text to start. It's not ideal, but it works
Power InRoads v8i 08.11.09.615
Microstation CONNECT 10.16.02.34
Microstation v8i SS 10 08.11.09.919
ORD CONNECT 2021 R1 10.10.1.3
ProjectWise 10.0.3.453
