Windows 11 upgrade option popped up on my machine this morning.
What's the official line on this? Wait for MSCE 16.2 or 16.3?
You're really fast dominc :-)
as ever read the system requirements of your product and released version , if they are unchanged so.... you stuck or work on your own risk with the NEW Windows 11.
Frank
Will be implemented in Q1 2023.
On a serious note: there was just a thread on a related issue: communities.bentley.com/.../675194
f.mandoki said:there was just a thread on a related issue: communities.bentley.com/.../675194
And also this newer one.
Jan
Wait for Bentley to certify use on 11. Don't expect there is much in Windows upgrade anyway.
Connect r16 10.16.03.11 self-employed
Thanks, guys.
Thought as much.
It would be good if Bentley could announce when it will certify for W11.
Microsoft is making it very easy to just click to upgrade. Very easy just to say yes... and there are those who will be buying new kit who will want to know which OS to have preinstalled.
