Is there any way to move multiple points to terrain intersection?
Hey guys
I´ve got a number of points that are placed on Z = 0 that I want to move up surface level. I can of course do this by moving each item individually, but I was looking for a way to move them all to their respective intersection point in a single operation. I´ve searched a bit on the forums with no success so far. I can´t seem to get the "move to contact" tool working properly, could be as simple as someone explaining how that works.
Thanks in advance!
  • Hi Samuel,
    I have had only limited success using the Move To Contact command.
    The video below shows an alternate method you could try.
    Ron
  • I´ve had the same luck using Move To Contact... And the intersection method didn´t really work either... But thanks for the tip!
