MS CE U16.
Hi.
In the "Raster manager" if an attached Raster appears as "is not found" because I moved the image file to another folder, how can I update the path (reattach) of the raster file?
Or I have to detach it and attach it again?
In the case of References dialog, we can double-click on the file to open the properties and press the [...] to select the same file in another location.
Thanks.
Joan Martínez Serra said:In the "Raster manager" if an attached Raster appears as "is not found" because I moved the image file to another folder
Prefer to use configuration variables to inform MicroStation about file locations. For reference and raster attachments, use MS_RFDIR.
MS_RFDIR
Joan Martínez Serra said:how can I update the path (reattach) of the raster file?
MS_RFDIR is a multi-path variable. Simply append the new path to the existing definition of that variable...
MS_RFDIR > //Server/references/new path/
Highlight the file in Raster Manager then go to <Utilities <File Name and navigate to the new folder.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Answer Verified By: Joan Martínez Serra
Jon Summers said:MS_RFDIR is a multi-path variable
Has it always been multipath? with append or is it a new thing in CE?
Wow!
Always learning new stuff even after 25 years
Lorys
As far as I am aware MS_RFDIR has been a multi-path variable. I use as shown in the screenshot
