It's possible to add others options (C, PL, CL, ...) in the dialog box for Suffix Text?
Thank you
It's always a good idea to mention the version of MicroStation you're currently using.
MicroStation Forum best practices
Unfortunately the symbols for the Prefix and Suffix Text are hardcoded into the software.
You might like to post this as a MicroStation Idea if it is required.
Linear Dimensioning
DIMENSION
PRE
OFF
DIAMETER
RADIUS
SQUARE
POST
Once the dimension is placed you can edit the text and add a symbol. Depending on the font chosen you will have different options.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
still same old problem we had in v8i and before...the problem is compounded if your active font doesnt support said symbols which is often the case..
I can use mixed font in dims , note leaders and text but its a pain in the B#*.. so I've reverted back to using cells with the right font text dropped to lines...not the best fix but quicker
In v8i ss10 the text favourites doesnt remember to use the different font ie say the active text is arial and you need the symbol from font 105 capital X ... you save it as a favorite under symbols and next time you try it doesnt remember the source font so you have to set the extra font and reselect it from the insert symbols.. So does it remember the right source font in CE so you only select the favourite?.. I havent tried in CE yet
Lorys
Lorys said:So does it remember the right source font in CE so you only select the favourite?.. I havent tried in CE yet
I just did an experiment with using an older .rsc font & a new TrueType font. I have the symbol from the TT font in my list of favorites. I was able to place text using the old .rsc font then I selected a symbol from my list and it is placed with the correct TT font. I did run into an issue though. If you try to edit the text Microstation crashes. The crash is probably expected since there are 2 different fonts and the program gets confused.
mwlong said:If you try to edit the text Microstation crashes. The crash is probably expected since there are 2 different fonts and the program gets confused.
Doesn't crash upon editing in V8iss10 on a piece of mixed font text.
Just doesnt remember the source font in the favourites so in v8i I name the favourite with the font no and Letter as part of the name
eg F105_8_Greater than .
So I can remember how to use it in mixed font.... bit more pc literate than a post_IT note on side of screen..
