We would like to know the end of life dates for the following MicroStation CONNECT Edition Updates:
- MicroStation CONNECT Edition Update 13,
- MicroStation CONNECT Edition Update 14,
- MicroStation CONNECT Edition Update 15.
Thank you in advance,
Not sure exactly what you're requesting in relation to "end of life" for these versions of MicroStation CONNECT Edition.
Under the current Desktop Applications Support Policy all CONNECT versions currently have Continuous Support.
I do not believe Bentley management have made any decisions about whether any of these recent versions would have an "end of life" date defined.
Answer Verified By: Charaf Eddine Atif
Hi Charaf,
I think that the assumption is that you will always upgrade your Microstation to the next update whenever it comes out. IE You're using Microstation CE, and the update date number just says if you're up to date, or you still need to apply the latest update.
I still open Microstation 7/J on (rare) occasion. The main issue that I have is the licensing is no longer available (or worth the effort) for Microstation J, so I have the time limit. Any version of Microstation CE will continue to work as long as nothing changes (hardware, software, dwg version) and the licensing method is operational.
If you need support, the answer may be "it works this way in the latest version, so you need to update..."
--Robert
