Is there a way to embed a raster file (CIT) into a DGN file and modify the raster file? AutoCad has this function and it very useful when you can manage only one file instead of two. Please review and let me know.
Lance, this forum is for feedback about the Communities site itself. Are you using MicroStation?
Yes. Is this not the right place to ask a question?
This is the Communities Feedback forum, for feedback about the use of this site. I will move your post to the MicroStation forum within the Product Communities section.
It depends on what you are meaning by "embedding" a raster (CIT) file using MicroStation. The easiest method would be to use Raster Manager to link an external raster file into your design. The following documentation should assist with using these tools.
Raster Manager Dialog
Another method could be to use the OLE tools in MicroStation to link or embed an external file.
Linking and Embedding Objects in the Product
As for making modifications to any attached raster images, this would probably not be able to be performed in plain MicroStation, but may also depend on what you mean by modify. I would suggest having a look at the Descartes software as an add-on to MicroStation which is available at an extra cost and can be installed during the main CONNECT version installation.
Descartes | Advanced Processing for 3D Imagery Software
Descartes Companion CONNECT Edition Installation
